I seems that ESRI has a serious limitation as it seems you can't symbolize the direction on water lines in ArcGIS Online. With server you can.
From the reading on Esri forums this is a known problem - caused by complex symbology needed on the line in the publishing MXD.
Just wondering if anybody has found a good work around they would share.
