I'm using ArcGIS 10 desktop version. I have a number of polygons, let's say 300, in a layer. Each polygon contains information of schools, ranging from 100 to 250 points, in a separate point layer. For example polygon "1A" will have all its points marked "1A" in the attribute table along with all other information. Same goes for polygon "2A" and "3A" and so on.Problem:As the points have been marked using GPS, a number of points of "1A" actually fall in other polygons, lets say "3A". Is there any idea through which I can select the points that belong to 1A but fall outside the polygon 1A. Switch selection does not work here as it selects the points of all other polygons.
Regards,
Regards,
