Surveyor @ Saudi Arabia
Job Description & How to Apply Below
Functions
 Manage the field crew personnel and equipment
 Carry out field surveys assigned by the survey supervisor/project engineer
 Perform observations and compare, standardize, and calibrate survey equipment.
 Compute and adjust first, second, and third order vertical and horizontal geodetic control networks.
 Transport, setup, operate, and maintain survey equipment.
 Perform preliminary field computations to verify field observations for control surveys and compute preliminary values of horizontal and vertical control points.
 Perform field checks to ensure the quality and integrity of field survey measurement to meet the project specifications and accuracy requirements.
 Convert grid and geodetic coordinates and transform coordinates to different coordinate systems.
 Downloading and uploading survey data between the survey instrument and the PC.
 Setup, operate, and maintain conventional and GPS survey equipment.
 Perform standard conventional and GNSS data measurement/observations.
 Prepare surveys and field notes.
 Processing of field survey data using professional surveying applications.
 Preparation of field data for layout from project design drawings.
 Input field-survey data into CAD programs and process CAD data into final products.
 Processing GPS data including real time kinematic (RTK), differential code and carrier phase, and static baseline processing
 Creating feature code libraries, survey styles, GIS data dictionaries, and coordinate systems for survey systems
 Performing quality checks to ensure that the final products meet the required project specifications.
http://www.learn4good.com/jobs/saudi_arabia/engineering/225913/e/#main_job_info
