I am in the process of designing a story map through ArcGIS Online, and I have recently found a way to embed a 3D Web Scene into the story map as a URL. This allows for me to display my 3D data effectively, but it takes away from my ability to set the extent/zoom to certain views when changing tabs within my story map journal. The map as the main stage content allows for different extents to be set to change the view depending on what you want to direct the user to, however since the web scene can only come in as a URL, it does not have the same level of detailing options for setting views.
I want my story journal to update locations based on different tabs similar to the Mountains of Fire Story Map. Does anyone have any idea how I can implement this?
Right now my theory is that they are using a completely different web scene for each of these different locations. Is there any way to check?
