When trying to drag the map, if the user clicks on a vector feature the featureselected event is triggered and the map dragging does not happen. Please try to drag the map starting from any feature in the example below.
http://openlayers.org/dev/examples/select-feature-multilayer.html
Is it possible to disable the featureselected event so the map can be dragged?
Solution
i found this FAQ http://trac.osgeo.org/openlayers/wiki/SelectFeatureControlMapDragIssues
It works.
Solution
It works.
