Step by step guide to complete your first drone mapping project
So you’ve heard about drone mapping, and you want to try it yourself, but you don’t know how to start. This step by step guide will help you do the first step. Basic level drone mapping is easier than you think. In fact, if you own one of the popular models of DJI Phantom 3, 4 or Mavic Pro (and there is a big chance you do) most of the stuff will happen automatically.
1. Selecting your drone.
The first thing is to select your UAV. The selection of drones on the market is huge but if you search for a drone that will be both: fun to use after hours and good enough for professional applications there is only one choice you should consider – one of DJI’s quadcopters. They are affordable, and there are plenty of useful smartphone apps that support DJI’s copters.
2. Selecting your drone mapping ecosystem
Once you got your DJI drone ready it’s time to choose a “mapping solution” that comprises of a smartphone app and a web*platform. The app will help to plan your flight properly, and it will take over the control of your DJI drone to automatically complete the survey. After the flight, you will have to transfer the data from your UAV to a computer. To do that you need to take the micro SD card from your drone, connect it to a computer and upload collected data to a web-based*tool that will process the data and let you view and analyze it.
The top three most popular platforms*out there are Pix4D, Drone Deploy, and*Data Mapper. Each of them offers both: the app and the web-based tool.
TIP:
The apps and the online platforms are not connected, so can mix different solutions.
Although each of these tools will do the job equally well, for the entry-level UAV mapping, we recommend you the Data Mapper app. It’s the easiest and the most straightforward, it’s not packed with features but it will do the job well and*there*are not too many things you can do wrong using it.
3. Planning your flight
Your main concern when flying a drone should be safety. For your first mapping project select an area without trees and high structures and never fly above people. The area of the project should not be too large and too small. 100x100m (or 300x300ft) should be just fine.
Once you’ve selected the area or a structure you want to map and you’ve installed Data Mapper on your smartphone, it’s time to make use of the app and plan the flight.
It’s very easy and you can do it in the field or at home. When you start the app, without any logging, it will ask you to plan a flight.
You need to click on the square on the left side of the screen and draw the area you want to map.
You can do it based on satellite images, but I’ve noticed that for some locations the images might be old and it might be difficult to do the planning properly. Error in the planning might cause crushing your drone and causing damage, so you need to be sure that the scope selected in the app is exactly fitting with the area you want to map. If the satellite imagery is old or there is a risk that by choosing a wrong scope you can crash your UAV there is a trick you can do.
TIP:
When being in the field the app will display your selected flight plan but also your location with a blue dot. Walk around the selected area and based on the location of your blue dot verify and adjust the scope of your project.
One of the most important parameters is the altitude of your flight. The lower the altitude, the more images your drone has to take to survey chosen area, the longer it will take to complete the survey and the more time and resource consuming the data processing. The altitude will also influence the pixel size. The reasonable approach is to relate the altitude to the size and height of your project area as well as expected accuracy. For a small area of below 100x100m (300x300ft) the flight on the altitude of 10 meters will take almost 10 min and will generate 150 images. Selecting altitude of 30 meters will shorten the flight time to 2 min and the number of images to 50. Knowing that the battery life will last a little over 20 min you can estimate what sort of area you can map on a single charge.
4. Take off
To take off you need to connect a smartphone to your DJI drone and simply tap on “Fly”. Confirm and take off.
TIP:
The app is controlling the trajectory of your flight and camera angle but it will not adjust the camera lighting settings. It will be the same as you left it the last time you’ve used your drone. It makes sense to verify and adjust the camera lighting settings via DJI Go app before your take off.
Now the drone will automatically take off and complete the survey based on the selected scope. Once the survey is completed or your device is running out of power the app will make your UAV come back to the starting point or land.
TIP:
If you are mapping structures like buildings, it’s recommended to capture some additional photos of these locations from different angles. It will make the 3D model look much better. In order to do that, you can select automated DJI’s mode “Point of Interest” or do it manually making sure that you capture all the details of the structure on a fairly low altitude.
5. Review your photos
If you have an opportunity to review the images still in the field, please do that. Particularly, at the beginning, it will save you a lot of time. During my first flight I had to go back to the field twice to get the effect I wanted to have.*You can also use the time to remove irrelevant images before processing. Pictures of the sky or taken at a strange angle might negatively influence the final effect of the orthomosaic and 3D model.
Remember that DJI doesn’t rename your images according to your flight plan, so on the SD card you will see all the images*named in order. Sorting out images from the flight your want to process and coping them to a separate folder will help you in the next steps.
6. Upload your images for processing
Ok. Now it’s time to upload your data. In order to do it you need to go to datamapper.com and create an account. You don’t need to give your credit card details and the first month is for free.
Go to Surveys and select Upload Survey.
Now select images you want to upload:
you will be also asked to fill in the camera details:
and select the output:
The output can be a flat areal image of the mapped area called “orthomosaic” (which is a result of stitching your pics together) or a 3D point cloud. Uploading your images might take a couple of minutes and then the data needs to be processed. The processing status bar is showed on the website and the process might take from a few minutes to a couple of hours depending on the scope of your project.
7. Enjoy and share your project
Once the processing is completed you will receive an email and the last thing to do is to enjoy your first mapping project!
Here is the Orthomosaic of the mapped structure:
The level of detail is really impressive.
You can switch to 3D view and play around with a 3D could point of the surveyed area.
Overall the basic drone mapping project is not a very complicated process and you can easy try it ourself. Stay tuned, we will soon move to more advanced stuff and review more drone mapping apps.
The post Step by step guide to complete your first drone mapping project appeared first on Geoawesomeness.
