I was asked to make StarFM, which creates a TimeSeries based on Temporal resolution of MODIS with the spectral resolution of Landsat work. Now, according to the barely-present help, it states that the program must be compiled in a linux environment. I have done this and the result is a .exe, so back to windows we go.I try to fire it up and it gives me an error stating
The version of %1 is not compatible with the version of windows.It then goes on to say that I should check if I have x64 or 32 bit system, but I am running on an x64, so even if it was x86, it should work perfectly fine. Has anyone else had any problems with this? Currently, I am trying to compile it in windows to see if that will fix it.
