SQL Geometry Query similar to Select by Centroid
Does anyone know if it's possible to query SQL geometry by something like 'centroid of polygon'...similar to ArcMap's select by location?
I'm using SQL Server 2008 R2 as the DBMS.
I have two polygon layers that are not exactly coincident and if I use STIntersects on the target polygon I get two different values where the polygons are not coincident. I was wondering if there is a query that can be used instead of STIntersects that would be similar to selecting the centroid of the polygon...?
Thanks in advance!
