I'm more of an ArcGIS user than a SQL Server user but I have polygon data in a 'geography' type in SQL 2008 R2. For a couple of these poly layers, I get this persistent drawing error in ArcMap:
Unsure how to find them in SQL (any help would be great!), I turned to ArcMap and used the Feature Vertices to Points tool to create a set of points at every vertex of my polys. I then calculated X and Y on those points. I can't find any instance where my Y exceeds either 90 or -90.
Unsure at this point...
One or more layers failed to draw:
Cultural Resource Site Polygon: Underlying DBMS error [[Microsoft][SQL Server Native Client 10.0][SQL Server]A .NET Framework error occurred during execution of user-defined routine or aggregate "geography": System.FormatException: 24201: Latitude values must be between -90 and 90 degrees. System.FormatException: at Microsoft.SqlServer.Types.GeographyValidator.ValidatePoint(Double x, Double y, Nullable1 z, Nullable1 m) at Microsoft.SqlServer.Types.Validator.BeginFigure(Double x, Double y, Nullable1 z, Nullable1 m) at Microsoft.SqlServer.Typ] [db.layer]
I thought at first this might be related to other posts I've seen on incorrect ring orientation in polygons but those errors tend to say that the data exceeds a hemisphere. This error seems to suggest that I have vertices inside some of my polys that are perhaps backwards.Cultural Resource Site Polygon: Underlying DBMS error [[Microsoft][SQL Server Native Client 10.0][SQL Server]A .NET Framework error occurred during execution of user-defined routine or aggregate "geography": System.FormatException: 24201: Latitude values must be between -90 and 90 degrees. System.FormatException: at Microsoft.SqlServer.Types.GeographyValidator.ValidatePoint(Double x, Double y, Nullable1 z, Nullable1 m) at Microsoft.SqlServer.Types.Validator.BeginFigure(Double x, Double y, Nullable1 z, Nullable1 m) at Microsoft.SqlServer.Typ] [db.layer]
