I am using ArcPad Data Manager from Arcmap 10.3 to export SPOT6 image to .apm file for Arcpad, and using it for field work, I exported it as background TIFF, the projection I used is :WGS_84_UTM_zone_23N. Everything was fine, but the image display somehow changed, I thought it because of SPOT6 has 4 bands, I composite them with first three bands, I also exported the image as GRID format, but none of them works. You can see clear difference between two images(below).Can anyone tell me how to figure this out? Thank you!
