Splitting Lines at Points ArcGIS
Hi all: following the suggestions of a thread here and several others, I made a set of points in order to split polylines at specified intervals. In order to do this, I used linear referencing to turn my lines into routes. Then, I exported the attribute table, divided each length by 5, and set points at multiples of 1/5 the length of the line. I used this as the event table to create a layer of events. So, each line has 4 equally spaced points along it, and I thus ultimately need the 5 segments separated by those points.
Curiously, though, when I try to do the second part "Split Line at Point," it seems that only one point is used on a given line at a time, and I'm not sure how it chooses the point (maybe order in its attribute table?) I could run the tool multiple times, but this doesn't seem to solve the problem either. For example, I could see how it would continue splitting segments as more segments are generated, but on e.g. the 4th run I see that some lines are still only split 3 times, even though there is a point within a line segment that was never split and existed before I ran the tool. I'm not sure how the splits are generated, but in any case, it doesn't seem to do what I want it to do, which is produce a split at "each" point.
What should I do to split lines at ALL points along the line?
