Split a volume (calculed between two surfaces)?
I recently generated a surface difference calcul, in order to make a 3D analysis of a volume (in blue on the image). I wanted now to split this final form into different part, in order to access to the volume information of each volume created (I used the "cut polygon" tool, that's why you can see a splitted polygon on the image). Unfortunately, when i looked into the table of attribute (when I used to read the information volume), this technique didn't worked. But the cutting process didn't splitted correctly the structure, Indeed, the volume of the splitted section correspond to the initial volume of the form (cf. picture ).
Anyone knows a technique to split a generated volume in order to acces the informations of each part ?
