In QGIS 2.12 the curves tool is integrated by default, I know. I would like to test the Spline Plugin whether it works better for my purpose or not (purpose is just to digitize streets mit nice curves, that's all).
The problem is, it doesn't work. There are the same edged lines as the standard drawing tool creates. I tried... ... to vary setting values. ... to reinstall the plugin. ... to use it in older versions (2.8 and 2.10). ... checking the option for ”suppress attribute form pop-up after feature creation” found in settings-options-digitizing-feature creation (as an answer to a similar question said).
None of this worked for me. Do I have to press a key while drawing or is there something else I can do?
