Spatial Query: The query from "LayerName" using "FID" in field not possible
In QGIS Wien, I am performing a spatial query with two layers (points and buffer areas) and receive the following error when creating a new layer with intersecting features: The query from "LayerName" using "FID" in field not possible.
Spatial query settings:- where the feature: intersects- and use the result to: create new selection
In the same file, I have performed the same spatial query with other layers (points and buffer areas) without running into this problem.
How should I go about fixing the error?
