Incoming solar radiation, insolation, is a vital aspect of the processes on earth that bring forth life. Insolation directly affects temperature by adding heat to the surface of the ground, and indirecty affects on evapotranspiration, photosynthesis, wind conditions, snow melt, and air and soil temperature. Paul Rich and Pinde Fu created insolation maps from digital elevation models (DEM) and used an insolation model that accounted for; atmospheric conditions, elevation, surface orientation, and influences of surrounding topography in the Rocky Mountains. That insolation model was used to focus on soil temperature measurements within this complex topography.
The researchers found that simple interpolation in areas with varied topographical terrain did not produce sufficient data to create high resolution soil temperature maps.In order to improve soil temperature calculations Rich and Fu created an insolation-modified soil temperature model that used a geometric insolation sub model. The researchers were able to create,with accuracy, high resolution temperature maps of their study area near the Rocky Mountain Biological Laboratory in Colorado. Understanding the levels and distribution of inoslation within varied topographies could potentially be helpful in avoiding forest fires or even determining the best time to plant crops, giving this research applications in forestry and agriculture.
Fu, P., & Rich, P. M. (2002). A geometric solar radiation model with applications in agriculture and forestry. Computers and electronics in agriculture, 37(1), 25-35.
