SimpliPy - Output File not an option
I am trying to implement line simplification on a polyline dataset using SimpliPy in QGIS but there is not an option for the output dataset. There are two notes mentioned in the plugins repository ( https://plugins.qgis.org/plugins/simplipy/ ):- You must have installed Shapely 1.2.18 or you will get an error installing or using this plugin.- The output can only be saved to a "New layer" for now. (The Output:Field isn't working).
Can anyone help me with that?
