I have multiple WMS in openlayers with a layer switcher and can be turned on and off. Now i have an image of each WMS, what i want is to show image of each WMS on click OF that corresponding WMS. Every WMS has only one polygon. How that can be done ? I apologize if it is a very basic question. Thanks
Below is my JavaScript code:
function initMap() { var osmLayer = new OpenLayers.Layer.OSM(); var gmap = new OpenLayers.Layer.Google("Google Streets", {visibility: false});var info;var Guyana= new OpenLayers.Layer.WMS("Guyana Country", "http://localhost:8080/geoserver/wms", { format: "image/png8", transparent: true, layers: "opengeo:guy_adm0", }, { opacity: 0.6, singleTile: true, visibility: true, });var Chile= new OpenLayers.Layer.WMS("Chile Country", "http://localhost:8080/geoserver/wms", { format: "image/png8", transparent: true, layers: "opengeo:chl_adm0", }, { opacity: 0.6, singleTile: true, visibility: true, });var Venezuela= new OpenLayers.Layer.WMS("Venezuela Country", "http://localhost:8080/geoserver/wms", { format: "image/png8", transparent: true, layers: "opengeo:ven_adm0", }, { opacity: 0.6, singleTile: true, visibility: true, });var Columbia= new OpenLayers.Layer.WMS("Columbia Country", "http://localhost:8080/geoserver/wms", { format: "image/png8", transparent: true, layers: "opengeo:col_adm0", }, { opacity: 0.6, singleTile: true, visibility: true, });var Argentina= new OpenLayers.Layer.WMS("Argentina Country", "http://localhost:8080/geoserver/wms", { format: "image/png8", transparent: true, layers: "opengeo:arg_adm0", }, { opacity: 0.6, singleTile: true, visibility: true, });var Bolivia= new OpenLayers.Layer.WMS("Bolivia Country", "http://localhost:8080/geoserver/wms", { format: "image/png8", transparent: true, layers: "opengeo:bol_adm0", }, { opacity: 0.6, singleTile: true, visibility: true, });var Paragua= new OpenLayers.Layer.WMS("Paragua Country", "http://localhost:8080/geoserver/wms", { format: "image/png8", transparent: true, layers: "opengeo
ry_adm0", }, { opacity: 0.6, singleTile: true, visibility: true, });var myWord = "SNOW COVER BASINS NORTHERN AREAS OF PAKISTAN";// Map with projection into (required when mixing base map with WMS) olMap = new OpenLayers.Map("divid", { projection: "EPSG:900913", displayProjection: "EPSG:32463", units: "m", layers: [gmap,osmLayer,Guyana,Chile,Venezuela,Columbia,Argentina,Bolivia,Paragua]});olMap.addControl(new OpenLayers.Control.LayerSwitcher());olMap.setCenter(new OpenLayers.LonLat(6011274.179826, -5256566558465465.6),3); }
