Shapefile/vector layer not appearing in QGIS
I have a shapefile (calling it 'new.shp' for discussion's sake) that won't show up with other layers. Basically, if a fresh file is started and I bring in new.shp, it will appear, but any other layers imported after does not. On the flip side, if other layers are imported first, the other layers appear, but new.shp will not show up.
That's not too much detail to troubleshoot from, but I was hoping someone might be able to suggest what the issue might be? I've just started learning GIS and using QGIS, so I'm a bit lost at the moment.
Other notes: - I looked into the CRS for new.shp which says (EPSG:4326, WGS 84); The other layers are also set to this. - Using QGIS 2.10.1 on Windows 7
