I'm following this tutorial. I installed the “GDAL Complete” Framework from kyngchaos.com and I tested the installation on Mac. I have GDAL 1.11.2, released 2015/02/10.
When I am trying to run this command:
ogr2ogr -f MySQL MySQL:dbname,user=root,password=password \ -nln world_borders -nlt MULTIPOLYGON \ -update -overwrite \ -lco ENGINE=MyISAM \ -lco MYSQL_FID=ogr_fid -lco GEOMETRY_NAME=geometry \ /path/to/TM_WORLD_BORDERS-0.3.shp With my settings it would be:
ogr2ogr -f MySQL MySQL:mapas,user=xxxx,password=xxxx \ -nln test -nlt MULTIPOLYGON \ -update -overwrite \ -lco ENGINE=MyISAM \ -lco MYSQL_FID=ogr_fid -lco GEOMETRY_NAME=geometry \ /Users/Seph/Downloads/TM_WORLD_BORDERS-0.3/TM_WORLD_BORDERS-0.3.shp I got this error:
Unable to find driver `MySQL'. The following drivers are available: -> `ESRI Shapefile' -> `MapInfo File' -> `UK .NTF' -> `SDTS' -> `TIGER' -> `S57' -> `DGN' -> `VRT' -> `REC' I have created the table on my database before running the command.
UPDATE I installed Homebrew I and ran this command:
brew install gdal --with-mysql Now I have the supported format: -> "MySQL" (read/write)
But now I have this error:
Macbook-pro:~ Seph$ ogr2ogr -f MySQL MySQL:mapas,user=xxxx,password=xxxx\ -nln test -nlt MULTIPOLYGON \ -update -overwrite \ -lco ENGINE=MyISAM \ -lco MYSQL_FID=ogr_fid -lco GEOMETRY_NAME=geometry \ /Users/Seph/Downloads/TM_WORLD_BORDERS-0.3/TM_WORLD_BORDERS-0.3.shp ERROR 1: MySQL connect failed for: mapas,user=xxxx,password=xxxx Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2) ERROR 1: MySQL connect failed for: mapas,user=xxxx,password=xxxx Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2) ERROR 1: MySQL connect failed for: mapas,user=xxxx,password=xxxx Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2) ERROR 1: MySQL driver doesn't currently support database creation. Please create database before using. MySQL driver failed to create MySQL:mapas,user=xxxx,password=xxxx I am using phpMyAdmin from Xammp
