A proxy page stands between a server and an application. By using*a proxy, you allow*an application to authenticate on your behalf, bypassing a challenge and*accessing secured services inside of an application.*While the token is hidden, an application can*access secured services with token-based authentication;*a proxy handles massive post requests over 2,048 characters.*Additionally,*you can use a proxy when a resource and an application are*on separate domains, as well as*when*cross-origin resource sharing*(CORS) support is unavailable.
Today, we’ll walk through the steps of downloading, setting up, and hosting a*proxy page on an IIS7 server.*For a programming language, we use Esri’s JavaScript API. In addition to setting up the proxy page, we will add a proxy rule to the Directions widget sample.
To download the Directions widget sample, click here.
Our journey begins at the glorious GitHub site.
Note: The proxy page must be located on the same server as your JavaScript application.
***************************** Folders under resource-proxy-masterTo view additional information within each folder located in the README.md, open the file with Notepad++ or a preferred*integrated development environment (IDE).
Input client id and secret inside the proxy.
Marla K. and Akshay H. – SDK Support Analysts
- Navigate to https://github.com/Esri/resource-proxy/releases*to obtain the most recent release of the proxy.
- Click ‘Source code(zip)’ to download the .zip file to your local drive.
Download a proxy from GitHub.
- Extract the files to your server (in this case, IIS Server), and navigate*to the resource proxy folder, ‘C:\\inetpub\wwwroot\resource-proxy-master’,*where you extracted the files. There are three sub-folders inside, each containing a proxy for the*respective server type:
- DotNet*-*Internet Information Services (IIS) server
- Java – Apache Tomcat server
- PHP*- Apache server
- Depending on the server, copy one of the*three folders. In this example, we*use an IIS server.*Copy the DotNet folder, and place*it in your wwwroot folder.
- Click Start. In*the ‘search for programs and files’ box, type IIS, and open the*IIS Manager.
- Expand the server name, the Sites folder, and Default Web Site.
Internet Information Services (IIS) Manager
- Right-click*the DotNet folder in the*directory, and*select*Convert to Application.
Convert proxy to an application
- Ensure the application pool is 4.0 or greater. In this example, we use ASP.NET v4.0. Ensure the folder icon is a*globe.
- In Windows Explorer,*open*the DotNet folder, and*right-click proxy.config.*Open*the file*in Notepad++ or*a*preferred IDE.
- Inside*the proxy.config file, you see the following in XML format:
proxy configuration file
We recommend*keeping the global mustMatch=”true”. When this is true, all requests made to the proxy can only go through specified serverUrls.
For testing purposes, you*can change the global mustMatch=”false”; this allows any proxy requests to pass through. - Since the direction’s sample uses http://route.arcgis.com and http://traffic.arcgis.com, we add two tags.
- The following steps demonstrate how to configure the proxy in your JavaScript application. There are a couple of ways to configure the proxy inside of a JavaScript application. For this particular example, we use the proxy rule.
- In the JavaScript application, add two proxy rules:
esri.addProxyRule({urlPrefix: “http://route.arcgis.com”, proxyUrl:”http:////proxy.ashx” });
esri.addProxyRule({** urlPrefix: “http://traffic.arcgis.com”, proxyUrl: “http:// //proxy.ashx” }); - As another possibility, add the “esri/urlUtils” module in the require statement,*and add the following rule:************************************************************************************************** ******* urlUtils.addProxyRule(urlPrefix: “route.arcgis.com”, proxyUrl:*”http:////proxy.ashx” });urlUtils.addProxyRule({urlPrefix: “traffic.arcgis.com”, proxyUrl: “http:////proxy.ashx”});**
- Here is another way to configure the proxy.
esriConfig.defaults.io.proxyUrl = “”
esriConfig.defaults.io.alwaysUseProxy = false;*
The proxyUrl is the path to your proxy page hosted on IIS.
- Run the hosted application, and open the Developer tools.
- Type in an origin and destination.*Our journey ends with step by step directions accompanied*by a map visual.*
Get Directions
