I have a small problem, I want to setTimeout on the geocode as the limit is 11 markers and I have 13 to display, I have tried wrapping different parts of the geocode in a setTimeout but cannot get it to work. Could this be done? as it is a wrapper for gmap.
I did originally use some more simple code but it would not work in IE, it just kept giving me the activex warning.
I have tried wrapping the whole return but can't seem to make it work.
Can anybody see a solution please.
/*** jQuery gMap - Google Maps API V3** @license MIT License; http://www.opensource.org/licenses/mit-license.php* @url http://github.com/marioestrada/jQuery-gMap* @author Mario Estrada based on original plugin by Cedric Kastner * @version 2.1.5*//* global google */(function($){// Main plugin function$.fn.gMap = function(options, methods_options){// Optional methodsswitch(options){case 'addMarker': return $(this).trigger( 'gMap.addMarker', [methods_options.latitude, methods_options.longitude, methods_options.content, methods_options.icon, methods_options.popup] );case 'centerAt': return $(this).trigger('gMap.centerAt', [methods_options.latitude, methods_options.longitude, methods_options.zoom]);case 'clearMarkers': return $(this).trigger('gMap.clearMarkers');}// Build main options before element iterationvar opts = $.extend({}, $.fn.gMap.defaults, options);// Iterate through each elementreturn this.each(function(){ // Create map and set initial options var $gmap = new google.maps.Map(this); $(this).data('gMap.reference', $gmap); // Create new object to geocode addresses var $geocoder = new google.maps.Geocoder(); // Check for address to center on if (opts.address) { // Get coordinates for given address and center the map $geocoder.geocode( { address: opts.address }, function(gresult, status) { if(gresult && gresult.length) { $gmap.setCenter(gresult[0].geometry.location); } } ); }else{ // Check for coordinates to center on if (opts.latitude && opts.longitude) { // Center map to coordinates given by option $gmap.setCenter(new google.maps.LatLng(opts.latitude, opts.longitude)); } else { // Check for a marker to center on (if no coordinates given) if ($.isArray(opts.markers) && opts.markers.length > 0) { // Check if the marker has an address if (opts.markers[0].address) { // Get the coordinates for given marker address and center $geocoder.geocode( { address: opts.markers[0].address }, function(gresult, status) { if(gresult && gresult.length > 0) { $gmap.setCenter(gresult[0].geometry.location); } } ); }else{ // Center the map to coordinates given by marker $gmap.setCenter(new google.maps.LatLng(opts.markers[0].latitude, opts.markers[0].longitude)); } }else{ // Revert back to world view $gmap.setCenter(new google.maps.LatLng(34.885931, 9.84375)); } } } $gmap.setZoom(opts.zoom); // Set the preferred map type $gmap.setMapTypeId(google.maps.MapTypeId[opts.maptype]); // Set scrollwheel option var map_options = { scrollwheel: opts.scrollwheel, disableDoubleClickZoom: !opts.doubleclickzoom }; // Check for map controls if(opts.controls === false){ $.extend(map_options, { disableDefaultUI: true }); }else if (opts.controls.length !== 0){ $.extend(map_options, opts.controls, { disableDefaultUI: true }); } $gmap.setOptions(map_options); // Create new icon var gicon = new google.maps.Marker(); var marker_icon; var marker_shadow; // Set icon properties from global options marker_icon = new google.maps.MarkerImage(opts.icon.image); marker_icon.size = new google.maps.Size(opts.icon.iconsize[0], opts.icon.iconsize[1]); marker_icon.anchor = new google.maps.Point(opts.icon.iconanchor[0], opts.icon.iconanchor[1]); gicon.setIcon(marker_icon); if(opts.icon.shadow) { marker_shadow = new google.maps.MarkerImage(opts.icon.shadow); marker_shadow.size = new google.maps.Size(opts.icon.shadowsize[0], opts.icon.shadowsize[1]); marker_shadow.anchor = new google.maps.Point(opts.icon.shadowanchor[0], opts.icon.shadowanchor[1]); gicon.setShadow(marker_shadow); } // Bind actions $(this).bind('gMap.centerAt', function(e, latitude, longitude, zoom) { if(zoom) { $gmap.setZoom(zoom); } $gmap.panTo(new google.maps.LatLng(parseFloat(latitude), parseFloat(longitude))); }); // Clear Markers var overlays = []; $(this).bind('gMap.clearMarkers', function() { while(overlays[0]){ overlays.pop().setMap(null); } }); var last_infowindow; $(this).bind('gMap.addMarker', function(e, latitude, longitude, content, icon, popup) { var marker_icon; var marker_shadow; var glatlng = new google.maps.LatLng(parseFloat(latitude), parseFloat(longitude)); var gmarker = new google.maps.Marker({ position: glatlng }); if(icon) { marker_icon = new google.maps.MarkerImage(icon.image); marker_icon.size = new google.maps.Size(icon.iconsize[0], icon.iconsize[1]); marker_icon.anchor = new google.maps.Point(icon.iconanchor[0], icon.iconanchor[1]); gmarker.setIcon(marker_icon); if(icon.shadow) { marker_shadow = new google.maps.MarkerImage(icon.shadow); marker_shadow.size = new google.maps.Size(icon.shadowsize[0], icon.shadowsize[1]); marker_shadow.anchor = new google.maps.Point(icon.shadowanchor[0], icon.shadowanchor[1]); gicon.setShadow(marker_shadow); } }else{ gmarker.setIcon(gicon.getIcon()); gmarker.setShadow(gicon.getShadow()); } if(content) { if(content === '_latlng') { content = latitude + ', ' + longitude; } var infowindow = new google.maps.InfoWindow({ content: opts.html_prepend + content + opts.html_append }); google.maps.event.addListener(gmarker, 'click', function() { if (last_infowindow) { last_infowindow.close(); } infowindow.open($gmap, gmarker); last_infowindow = infowindow; }); if(popup) { google.maps.event.addListenerOnce($gmap, 'tilesloaded', function() { infowindow.open($gmap, gmarker); last_infowindow = infowindow; }); } } gmarker.setMap($gmap); overlays.push(gmarker); }); var marker; var self = this; var geocode_callback = function(marker) { return function(gresult, status) { // Create marker if(gresult && gresult.length > 0) { $(self).trigger( 'gMap.addMarker', [gresult[0].geometry.location.lat(), gresult[0].geometry.location.lng(), marker.html, marker.icon, marker.popup] ); } }; }; // Loop through marker array for (var j = 0; j < opts.markers.length; j++) { // Get the options from current marker marker = opts.markers[j]; // Check if address is available if (marker.address) { // Check for reference to the marker's address if (marker.html === '_address') { marker.html = marker.address; } // Get the point for given address $geocoder.geocode({ address: marker.address }, geocode_callback(marker)); }else{ $(this).trigger('gMap.addMarker', [marker.latitude, marker.longitude, marker.html, marker.icon, marker.popup]); } }});};// Default settings$.fn.gMap.defaults = {address: '',latitude: 0,longitude: 0,zoom: 1,markers: [],controls: [],scrollwheel: false,doubleclickzoom: true,maptype: 'ROADMAP',html_prepend: '',html_append: '
',icon: { image: "http://www.google.com/mapfiles/marker.png", shadow: "http://www.google.com/mapfiles/shadow50.png", iconsize: [20, 34], shadowsize: [37, 34], iconanchor: [9, 34], shadowanchor: [6, 34]}};})(jQuery);
