"Sequence size" doesn't match row in Python?
Essentially I am trying to calculate a value for a couple of fields after adding them. Below you can see how I am adding the fields and then an example on how my "for" statement is looping through the cursors to add values.
I keep getting an error: "TypeError: sequence size must match size of the row"
I'm not sure what to do about this. Is there a better method than to use the UpdateCursor updateRow statements?
fieldName = ["azVEqSet", "azVERis"]try: arcpy.AddField_management(points, fieldName[0] ,"FLOAT") arcpy.AddField_management(points, fieldName[1] ,"FLOAT")except: arcpy.DeleteField_management(points, [fieldName[0], fieldName[1]]) arcpy.AddField_management(points, fieldName[0] ,"FLOAT") arcpy.AddField_management(points, fieldName[1] ,"FLOAT")cursor = arcpy.da.UpdateCursor(points, ["azVEqSet", "azVERis", "POINT_X", "RASTERVALU", "POINT_Y"])for row in cursor:... numberInsert = ReturnedVariable row[0] = numberInsert cursor.updateRow([row])
