I am trying to map the following projection but having issues finding a one that works. I ahve used http://prj2epsg.org/search which gives a few results but none seem to work that well.
PROJCS["NAD_1983_HARN_WISCRS_Bayfield_County_Feet", GEOGCS["GCS_North_American_1983_HARN", DATUM["D_North_American_1983_HARN", SPHEROID["GRS_1980", 6378137.0, 298.257222101]], PRIMEM["Greenwich", 0.0], UNIT["degree", 0.017453292519943295], AXIS["Longitude", EAST], AXIS["Latitude", NORTH]], PROJECTION["Lambert_Conformal_Conic_2SP"], PARAMETER["central_meridian", -91.15277777777777], PARAMETER["latitude_of_origin", 46.66964837722222], PARAMETER["scale_factor", 1.0000331195], PARAMETER["false_easting", 750000.0010000002], PARAMETER["false_northing", 487372.65900000004], UNIT["foot_survey_us", 0.3048006096012192], AXIS["X", EAST], AXIS["Y", NORTH]]Use Prj2EPSG with the text above (which is what geoserver sees as the native SRS), I get matched with 2236,2241,2239,2254,2257,2260..etc
When I use the prj file instead, I get this.
PROJCS["NAD_1983_HARN_WISCRS_Bayfield_County_Feet",GEOGCS["GCS_North_American_1983_HARN",DATUM["D_North_American_1983_HARN",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["False_Easting",750000.001],PARAMETER["False_Northing",487372.659],PARAMETER["Central_Meridian",-91.15277777777779],PARAMETER["Standard_Parallel_1",46.66964837722222],PARAMETER["Scale_Factor",1.0000331195],PARAMETER["Latitude_Of_Origin",46.66964837722222],UNIT["Foot_US",0.3048006096012192]]These match with 3857,24370..etc Obviously the two are different. Geoserver must be parsing it a bit different than prj2epsg does. prj2epsg uses the exact text of the prj file.
After trying to set a few of the declared SRS. When I go to Data->Layer Preview. The layer will show up how it should look just fine. However, when I go to Tile caching -> Tile Layers, both the 4326 and 900913 don't show anything. Typically they show up just fine with most of my other layers. Granted those were easier to use since they were 4326 to start with.
Any suggestions would be helpful.
EDIT: When I select 2236 for example. I can get it to work. However, it shows up in flordia instead of wisconsin. That makes sense since it is pretty much trying to project it on the map in florida. Sounds like I need a custom projection for this? Not sure?
