Selecting numbers within the slash (/) using ArcMap Field Calculator
I have date data that I'm separating into three separate fields (all fields are string type) by day, month, and year. Unfortunately, the date field is raw data and isn't consistent; there are eight variations for how the data in this field is organized (d/m/yy; d/m/yyyy; d/mm/yy; d/mm/yyyy; dd/m/yy; dd/m/yyyy; dd/mm/yy; dd/mm/yyyy). I figured out how to separate the day and the year into separate columns, but I'm having difficulty separating the month. I've tried the VB Script Mid() function by initially separating the different formats and performing the function, but that was extremely time-consuming, and I have close to 100,000 data points that I need to go through. Is there a python code that I can use, or a combination of different VB scripts, that can select the numbers between the slashes (/) for all of these? Or am I doomed?
Any guidance is greatly appreciated.
