Select points located within Multi Ring Buffer
I have two point datasets, 1 showing the location of road accidents, the other showing the location of traffic intersections. I have created a Multi Ring Buffer at 25m intervals around the traffic intersections buffer (ie: a buffer at 25m, 50, 75m, etc.)
I want to select points from the road accidents buffer that fall within the 25m buffer, excluding those outside.
I then want to select points within the 50m buffer, excluding those which fall inside the 25m buffer and outside the 50m buffer. I'll then repeat this process for the remaining buffer.
How would I go about selecting points within the 50m buffer while excluding those that fall outside it and within the 25m buffer?
Cheers! :)
