How to build a model takii way to avoid this error? I need to layer the missing tool is created automatically or miss it and extending those layers in MXD are available in gdb ...More specifically, I will have gdb with layers:
U_XX_XXX:UA_XX_XXX:LU_XX_XXXLUA_XX_XXXPART_XX_XXXPARTA_XX_XXXOT_XX_XXXOTA_XX_XXXUK_XX_XXXR_XX_XXX
where XX - StaffXXX - DistrictThat is, the layers will be very much, and some will not be any in stock!This instrumenov you type XX and XXX once dobovlyaet desired layers in MXD. But the problem is that in the absence of at least one layer of the tool is not working!
What can you advise?
