"select by attribute" error, when using getParameter
I'm developing an ArcGIS tool by Python. Below is a part of the inputs:
StudyArea = arcpy.GetParameterAsText(0)
LandCover = arcpy.GetParameterAsText(1)
gridcode = arcpy.GetParameterAsText(2)
gridcode is a field from LandCover.
gridcode aims to derive the field which contains land cover class code.
Then I try to select some land cover types (land cover code < 17 and = 21), and the code I write is:
arcpy.SelectLayerByAttribute_management("LC_test","NEW_SELECTION",'gridcode
