Search Functionality using Cartodb API
I posted a similar question about this a month or so ago and I was still in early stages of researching the problem thus not to many results came from it .After some time and effort I have come close to having my desired results. The goal is to have a search box that queries the table on my cartodb account and then results get sent back to the API. The code below works as described however that is because I have the value of the form hard coded. I did this to show that the function is correct and that the value does get passed on the the query.My problem thought is once i delete the hard coded value and try to type the text in, the query results on my Console are blank. So some where the value is getting dropped and I am not quite sure where. (I posted the whole code so that you can copy and paste to see the results...If desired)
Bounds example | CartoDB.js html, body, #map { height: 95%; padding: 0; margin: 0; }
