Script runs in ArcMap Python window but not in stand alone Python win or IDLE
I am attempting to automate some basic geoprocessing for a web map service. I am using ArcGIS 10.1 for Desktop.
This code was built in ModelBuilder and exported to python.
This runs perfectly in ArcGIS for Desktop.
However it returns error 000732 for both the "Service_Group" dataset and the Excel sheet that are to be joined when ran Outside of Arc.
I have changed the #Local Variables to a UNC path with no luck.
import arcpy mxd = arcpy.mapping.MapDocument(r"X:\Mikes_Workspaces\Outage\Outage.mxd") df = arcpy.mapping.ListDataFrames(mxd,"Layers")[0] # Script arguments OutCurrent = arcpy.GetParameterAsText(0) if OutCurrent == '#' or not OutCurrent: OutCurrent = "X:\\Geodatabases\\WebData\\Water_Service.gdb\\OutCurrent" # provide a default value if unspecified # Local variables: Service_Group = "Service_Group" Update_ = "S:\\Pump and Canal Patrol\\Water On\\4-7-15\\Outage_Board.xls\\Update$" Group_Out = "Service_Group" # Process: Add Join arcpy.AddJoin_management(Service_Group, "Group_", Update_, "Group_Out", "KEEP_COMMON") # Process: Copy Features arcpy.CopyFeatures_management(Group_Out, OutCurrent, "", "0", "0", "0") # Process: Symbology arcpy.ApplySymbologyFromLayer_management("OutCurrent", "X:\Mikes_Workspaces\Online Shapefiles\Outage_today.lyr") # Process: Remove Join arcpy.RemoveJoin_management(Service_Group, "") This is the error received:
Traceback (most recent call last): File "C:\Python27\ArcGISx6410.1\Lib\site-packages\Pythonwin\pywin\framework\scriptutils.py", line 326, in RunScript exec codeObject in __main__.__dict__ File "E:\GIS\Mikes_Workspaces\Automation\OutageUpdate.py", line 15, in arcpy.AddJoin_management(Service_Group, "Group_", Update_, "Group_Out", "KEEP_COMMON") File "C:\Program Files\ArcGIS\Server\arcpy\arcpy\management.py", line 5325, in AddJoin raise e ExecuteError: Failed to execute. Parameters are not valid. ERROR 000732: Layer Name or Table View: Dataset Service_Group does not exist or is not supported ERROR 000732: Join Table: Dataset S:\Pump and Canal Patrol\Water On\4-7-15\Outage_Board.xls\Update$ does not exist or is not supported Failed to execute (AddJoin).
