SAGA-Inverse Distance Weighting in QGIS - How to Set Minimum Number of Points?
I am analyzing a postGIS point dataset in QGIS version 2.8.2, about 200k features total. To calculate weighted average values I am using the Inverse Distance Weighted interpolation technique. However, I am concerned that the "high" values I'm seeing in the outputs are the result of a handful of outlier values, not the basis of any meaningful spatial pattern.
Is there a way in the SAGA IDW plugin - or another IDW tool - to set a minimum number of points required for the raster surface to calculated the weighted averages, the same way it considers a maximum number of points?
