Runtime error : ERROR 000358: Invalid expression using SelectLayerByAttribute in ArcP
I cannot for the life of me persuade SelectLayerByAttribute to work (I need to automate this for a complex script). Working in ArcMap's python console on already loaded shapefile, the format below:
import arcpy from arcpy import env arcpy.env.workspace = r"C:/Users/.../working" arcpy.SelectLayerByAttribute_management("layer", "NEW_SELECTION", " 'ATTRIBUTE' = 'Criterion' ") results in error:
Runtime error : ERROR 000358: Invalid expression Failed to execute (SelectLayerByAttribute).
An alternative method:
import arcgisscripting import arcpy gp = arcgisscripting.create(9.3) gp.workspace = "C://...//working" sFile = "C://...//working//shapefile.shp" lyr = "layer" gp.makefeatureLayer_management(sFile, lyr) gp.toolbox = "management" gp.SelectLayerByAttribute("layer", "NEW_SELECTION", " 'ATTRIBUTE' = 'Criterion' ") .. selects everything, including features that don't meet the criterion!
Does anyone have any idea what's going wrong? I've read some pages on this problem, but found no solution that works here. The working directory is correct. The attribute field and criterion are correctly specified (case sensitive etc), etc. Its very confusing.
