Running PyQGIS script directly (without using interface)?
I wrote the following script, which runs fine from the QGIS python console (it loads two shapefiles, intersects them, and then finds the areas of the new regions):
import qgis.utilsimport qgis.corefrom qgis.analysis import *from PyQt4.QtCore import QVariantimport osprint(os.getcwd())layer1 = iface.addVectorLayer("/Users/casta2k/ShapefilePractice/precincts/USA_precincts.shp", "precincts", "ogr")layer2 = iface.addVectorLayer("/Users/casta2k/ShapefilePractice/data_EPSG_4326/Bnd_2015_q1_region.shp", "zipcodes", "ogr")overlayAnalyzer = QgsOverlayAnalyzer() overlayAnalyzer.intersection(layer1, layer2, "/Users/casta2k/ShapefilePractice/intersect/intersectOutput.shp")layer3 = iface.addVectorLayer("/Users/casta2k/ShapefilePractice/intersect/intersectOutput.shp", "intersect", "ogr")layer = iface.activeLayer()provider = layer.dataProvider()areas = [ feat.geometry().area() for feat in layer.getFeatures() ]field = QgsField("area", QVariant.Double)provider.addAttributes([field])layer.updateFields()idx = layer.fieldNameIndex('area')for area in areas: new_values = {idx : float(area)} provider.changeAttributeValues({areas.index(area):new_values})I'd like to be able to run the code directly from a python script, without having to open the GUI. I've tried searching the internet, but I've found nothing helpful. Do I have to start by running QgsApplication.initQgis()? I thought I had to, but I get a segmentation fault. Also, I tried changing iface.addVectorLayer() to QgsVectorLayer(), which seems to work fine in the Python console, but it seems like the files aren't loaded when I run the python script directly.
I tried to include what @Paulo suggested, but I'm still getting errors. The code now starts as follows:
import sysimport ossys.path.append("/Applications/QGIS.app/Contents/Resources/python")from qgis.core import *import qgis.utilsfrom qgis.analysis import *# supply path to where is your qgis installedQgsApplication.setPrefixPath("/Applications/QGIS.app/Contents/MacOS", True)# load providersQgsApplication.initQgis()But on the last line (QgsApplication.initQgis()) I'm getting the following error:
QCoreApplication::applicationDirPath: Please instantiate the QApplication object firstQCoreApplication::applicationDirPath: Please instantiate the QApplication object firstSegmentation fault: 11
