I've got an error in JSTS (JavaScript Topology Suite) library based on JTS v1.12 (r405).But there is no error in the last build of JTS on the same test case. So I want to check this test case in older JTS v1.12.
However, I can't run the GUI (testbuilder.bat) due to error
Could not find the main class. Program will exit.
under Windows, and in Ubuntu:
neadmin@myubuntu:~/SVN/JTS/jts/bin$ ./testbuilder.shException in thread "main" java.lang.NoClassDefFoundError: com/vividsolutions/jtstest/testbuilder/JTSTestBuilderCaused by: java.lang.ClassNotFoundException:com.vividsolutions.jtstest.testbuilder.JTSTestBuilder at java.net.URLClassLoader$1.run(URLClassLoader.java:217) at java.security.AccessController.doPrivileged(Native Method) at java.net.URLClassLoader.findClass(URLClassLoader.java:205) at java.lang.ClassLoader.loadClass(ClassLoader.java:323) at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:294) at java.lang.ClassLoader.loadClass(ClassLoader.java:268)Could not find the main class: com.vividsolutions.jtstest.testbuilder.JTSTestBuilder. Program will exit.
I have Windows 7 x64 (or Ubuntu 14.04) and Java 5u22 (or 6u45)....
Any help will be appreciated.
