Rule -torque-frame-count not allowed for Map
I'm simply trying to recreate a map I've already made successfully but with an updated table. I added the table to CartoDB, selected "Map View," and then selected "Torque Cat." Aside from doing those things, I've done no editing, but I'm receiving the following errors:
There is a problem with the map tiles. Please, check your CartoCSS styleAnd when I open the CSS Editor, I see this error:
line 4: Rule -torque-frame-count not allowed for Map.Here's my CartoCSS:
/** torque_cat visualization */Map {-torque-frame-count:512;-torque-animation-duration:30;-torque-time-attribute:"cartodb_id";-torque-aggregation-function:"CDB_Math_Mode(torque_category)";-torque-resolution:2;-torque-data-aggregation:linear;}#all_flights_201410011911_lines_smoothed_mas_pt{ comp-op: source-over; marker-fill-opacity: 0.9; marker-line-color: #FFF; marker-line-width: 1.5; marker-line-opacity: 1; marker-type: ellipse; marker-width: 6; marker-fill: #FF9900;}#all_flights_201410011911_lines_smoothed_mas_pt[frame-offset=1] { marker-width:8; marker-fill-opacity:0.45; }#all_flights_201410011911_lines_smoothed_mas_pt[frame-offset=2] { marker-width:10; marker-fill-opacity:0.225; }#all_flights_201410011911_lines_smoothed_mas_pt[value=1] { marker-fill: #A6CEE3;}Seeing as I've done nothing but selected defaults, I'm at a loss for how to fix this. Any help is appreciated. Thanks!
