Road Topology Problem solution for junction
I am working with a Road Network. I have digitized the lines with AutoCAD Map 3D. Then Imported it to ArcMap. After entering all kind of database I have created Routing Dataset. But unfortunately its not giving the desired route. The most probably problem may be the junction. I think there are few problems with junction between the road. Its a huge database and it cant be check manually every junction. Is there any way to create a network topology to check the junctions easily whether the roads snapped or not?
Thanks
