I am attempting to cast a MultiLineString feature in WGS84 to UTM33N using RGeo.
Unfortunately, RGeo::Feature.cast, instead of casting the feature to the desired projection, returns the original feature unchanged, as the checks at the end show. Why does the conversion result like this? What else is needed to convert between these two projections in RGeo?
require 'rgeo' require 'rgeo-geojson' utm_33n_factory = RGeo::Geographic.spherical_factory
srid => 32633) wgs_84_factory = RGeo::Geographic.spherical_factory
srid => 4326) geo_json = '{"type":"Feature","properties":{"City":"PRG","Name":"Z","Color":"green","Description":"Pohorelec"},"geometry":{"type":"MultiLineString","coordinates":[[[14.389935,50.087667,0],[14.389219,50.08756,0],[14.389093,50.087525,0],[14.388617,50.087394,0]]]}}' json_geom = RGeo::GeoJSON.decode(geo_json, geo_factory: wgs_84_factory, json_parser: :json).geometry projected = RGeo::Feature.cast json_geom, factory: utm_33n_factory, project: true puts json_geom.equal? projected # => true puts projected.srid # => 4326
