Reprojecting MODIS-Sphere ESRI GRID file to WGS84 using QGIS/GDAL
I have an ESRI GRID file projected in MODIS-Sphere (here's the dataset http://urban.yale.edu/sites/default/files/data/setoguneralphutyra_uf.zip) that I need to convert to a WGS84 GeoTIFF.
I tried Raster > Projections > Warp (Reproject) and got this nonsense:
I then thought I'd use the MODIS reprojection tool or HEG to convert it, but they only accept HDF files and using QGIS' warp or translate functions to convert this file to HDF throwns an error. This guy was trying to do the same thing in Arc, no joy:MODIS-Sphere to WGS84 coordinate system in ArcGIS
I looked for clues in the metadata, and the file seems a little goofy; gdalinfo yields:
Driver: AIG/Arc/Info Binary GridFiles: seto_uf seto_uf.aux seto_uf/.aux.xml seto_uf/.DS_Store seto_uf/dblbnd.adf seto_uf/hdr.adf seto_uf/log seto_uf/metadata.xml seto_uf/sta.adf seto_uf/vat.adf seto_uf/w001001.adf seto_uf/w001001.tif seto_uf/w001001.tif.aux.xml seto_uf/w001001x.adfSize is 7468, 2911Coordinate System is `'Origin = (-17345341.010356999933720,8423784.764957003295422)Pixel Size = (5000.000000000000000,-5000.000000000000000)Corner Coordinates:Upper Left (-17345341.010, 8423784.765) Lower Left (-17345341.010,-6131215.235) Upper Right (19994658.990, 8423784.765) Lower Right (19994658.990,-6131215.235) Center ( 1324658.990, 1146284.765) Band 1 Block=256x4 Type=Byte, ColorInterp=Undefined Description = Seto_UF Min=0.000 Max=101.000 NoData Value=255So it can't determine the coordinate system.
There's a .tif included in the directory, but gdalinfo on that shows:
Driver: GTiff/GeoTIFFFiles: w001001.tif w001001.tif.aux.xmlSize is 7468, 2911Coordinate System is:GEOGCS["Unspecified datum based upon the GRS 1980 Authalic Sphere", DATUM["unknown", SPHEROID["unnamed",6371007,1]], PRIMEM["Greenwich",0], UNIT["degree",0.0174532925199433], AUTHORITY["EPSG","4047"]]Origin = (-17345341.010356999933720,8423784.764957003295422)Pixel Size = (5000.000000000000000,-5000.000000000000000)Metadata: AREA_OR_POINT=AreaImage Structure Metadata: INTERLEAVE=BANDCorner Coordinates:Upper Left (-17345341.010, 8423784.765) Lower Left (-17345341.010,-6131215.235) Upper Right (19994658.990, 8423784.765) Lower Right (19994658.990,-6131215.235) Center ( 1324658.990, 1146284.765) So it says the units are degrees but those huge corner coordinates and origin values don't agree.
Any ideas?
My setup:
OSX 10.9.4
QGIS 2.6.1 Brighton
GDAL 1.11.2 (apparently there are newer versions but this is the latest you can get on OSX without having to compile it yourself)
