I have fetch data from database and draw it on qgis 2.8 as vector layer it works fine with limited data but for large data it will not work and goes into not responding stage, I am unable to understand the problem. My code is follows
layer = QgsVectorLayer("Point?field=gid:integer&field=lattitude:double& field=longitude:double&field=depth:integer &crs=EPSG:4326","items","memory") QgsMapLayerRegistry.instance().addMapLayer(layer) for i in range(len(Receivers)): # add a feature feature = QgsFeature() X = Receivers[1] Y = Receivers[2] temp=[] #X= X cordinate longitude #Y= Y cordinate latitude feature.setGeometry(QgsGeometry.fromPoint(QgsPoint(Y,X))) length=len(Receivers) for j in range(0,length): temp.append(Receivers[j]) feature.setAttributes(temp) layer.startEditing() layer.addFeature(feature, True) layer.commitChanges() layer.updateExtents()Receiver list contain the data fetch from database (postgres)
