Rendering and Labeling Shapefile with PyQGIS
I've been running into a few problems working with the QGIS API for python. I've gotten more comfortable working in the python console in QGIS but I run into problems when I try to run the code outside of QGIS.
Basically I want to take a shapefile, label it based on the specified attribute name, and render an image. The code works in QGIS, but does not work outside of of QGIS. So where is my problem coming from?
import sys import qgis import PyQt4 from qgis.core import * from qgis.utils import * from qgis.gui import * from PyQt4.QtCore import * from PyQt4.QtGui import * #initialize QGIS QgsApplication.setPrefixPath( r"C:\OSGeo4W64\apps\qgis", True ) QgsApplication.initQgis() #Add layer to instance file = QgsVectorLayer("Good Shape File", "BMAS", "ogr") QgsMapLayerRegistry.instance().addMapLayer(file) #Adjust layer Settings #Code sample from http://gis.stackexchange.com/questions/77870/how-to-label-vector-features-programmatically palyr = QgsPalLayerSettings() palyr.enabled = True palyr.fieldName = 'Attribute' palyr.placement= QgsPalLayerSettings.OverPoint palyr.setDataDefinedProperty(QgsPalLayerSettings.Size,True,True,'8','') palyr.writeToLayer(file) if file.isValid(): print "File is valid." mapRenderer = iface.mapCanvas().mapRenderer() lst = [file.id()] mapRenderer.setLayerSet(lst) mapRenderer.setLayerSet( lst ) c = QgsComposition(mapRenderer) c.setPlotStyle(QgsComposition.Print) x, y = 0, 0 w, h = c.paperWidth(), c.paperHeight() composerMap = QgsComposerMap(c, x,y,w,h) c.addItem(composerMap) composerLabel = QgsComposerLabel(c) composerLabel.adjustSizeToText() c.addItem(composerLabel) composerLabel.setItemPosition(20,10) composerLabel.setItemPosition(20,10, 100, 30) legend = QgsComposerLegend(c) legend.model().setLayerSet(mapRenderer.layerSet()) c.addItem(legend) #set image sizing dpi = c.printResolution() dpmm = dpi / 25.4 width = int(dpmm * c.paperWidth()) height = int(dpmm * c.paperHeight()) img = QImage(QSize(width, height), QImage.Format_ARGB32) img.setDotsPerMeterX(dpmm * 1000) img.setDotsPerMeterY(dpmm * 1000) img.fill(0) imagePainter = QPainter(img) sourceArea = QRectF(0, 0, c.paperWidth(), c.paperHeight()) targetArea = QRectF(0, 0, width, height) #renders image c.render(imagePainter, targetArea, sourceArea) imagePainter.end() img.save("E:/QGisTestImages/out.png", "png") I'm able to do the simple rendering example in the python cookbook, so I think my paths are set up correctly.
"Good Shape File" should be replaced with a good path location if you want to run this. And palyr.fieldName = 'Attribute' should be set to a valid field name for that shapefile.
Edit: I have gotten rid of iface and inserted code for the extent between the mapRenderer initialization and the lst declaration.
mapRenderer = QgsMapRenderer() rect = file.extent() mapRenderer.setExtent(rect) mapRenderer.setLabelingEngine(QgsPalLabeling()) lst = [file.id()] Edit: I added
app = QgsApplication([], True) after
QgsApplication.initQgis() and the code worked.
