I'm setting up a tile server using the guide provided here.
I have everything set up. proj4 is installed in version 4.8.0. The espg file is existant, I ran an xmllint over my xml style file without errors. mod_tile is also running without problems. I also have a fully populated PostGIS database running. I used osm2pgsql.
The problem is starting renderd. It gives me the following error message:
renderd[25257]: An error occurred while loading the map layer 'default': failed to initialize projection with: '+init=epsg:4326' encountered during parsing of layer 'necountries' in Layer at line 58 of '/src/mapnik-style/osm.xml'(I inserted line breaks for legibility)
It's the only error message. Everything else works fine.
I checked for the espg file at /usr/local/share/proj/epsg which is present and contains (of course) the WGS84 definition.
I googled around but couldn't find something. There were hints to the proj4 library. But since it's installed in version 4.8.0, i can't see the problem.
Thanks for the help!
