I have a village level shapefile. Using Dissolve_management, I collapse the villages to district level. I also use Multi_Part option to prevent multiple entries for same polygon and so the resulting file has one row for each district.
The issue is that the village file has very tiny gaps between villages. When I use Dissolve_management, these gaps/slivers/holes are appearing in the resulting District Polygons. Since there are hundreds of these districts and within each district there are multiple slivers, I want to automate the process of sliver removal from within the polygons.
So the question is: Is there a way to remove these empty spaces/slivers from the larger district polygons? I want these slivers to be part of the polygons they lie in.
