I have:
I can't get this done on the on the remote server for a variety of logistical reasons.
I had attempted to build Views (of the simplest Select * from mytable variety) that were giving me a degree of success in SQL when I invoked the OPENQUERY option, which had functioned but now are returning me:
The OLE DB provider "SQLNCLI10" for linked server "xx.xxx.xx.xxx\MSSQL2008R2" supplied inconsistent metadata for a column. The column "Geom" (compile-time ordinal 4) of object "SELECT ColimnID, Column2, Column3, Geom, Column4, Column5, Column6, Column7, Column8, Column9, Column10FROM remotedata.dbo.mytable " was reported to have a "Incomplete schema-error logic." of 0 at compile time and 0 at run time.In the absence of being able to perform the joins within SQL directly because of this I'm instead trying to do some of the geo-manipulation in the Crystal context.This however is presenting a secondary set of challenges;what could ordinarily be expressed as
mytable.geom.STX
now needs to be
geometry::STGeomFromText(CONVERT(nvarchar(50),"mytable"."Geom"), 0).STX
or at least in that construct I can get it to work when entered as a SQL expression field within Crystal.
Unfortunately the really thorny Join that I need to perform
mytable as a INNER JOINmybasereference AS b ON b.geom.STContains(a.Geom)=1 and I have absolutely come to a dead end as to how (or even IF) this is theoretically possible within Crystal let alone how to make it read correctly for Crystal to process.
I'm agnostic as to where I invoke this join within the entire processing as it only provides me with a reference- but a necessary one
ANY suggestions gratefully received
- A remote SQL server (2008 R2) that I have access to (But NOT full control of) which contains my source data including OSGB 1936 Geometry [ESPG: 27700]
- In house SQL Server 2008 R2
- A Crystal Report Automator in house that allows me to send multiple variants of a report in PDF format to multiple recipients (500+)
- Crystal XI
- limited comprehension of CLR Package installations!
mytable.geom.STX
now needs to be
