I am trying to conduct atmospheric adjustment of Landsat 8 image bands using 6s algorithm (i. atcorr grass gis tool). It seems, in the input section, an elevation raster map should be provided. In my literature review, I could not find any reference discussing the DEM's relevance in the process. It is not a required option either. Any explanation how and where it fits in the overall process? In my control file, I am already providing average height above msl (of surface I want to correct). My earlier attempts at correction led to max values above 1 (which is unusal, I was told). Want to explore if the DEM makes any difference or not. Anyways, I may need the DEM for topographic corrections later.
I am trying to be consistent with the data. The Elevation source in line 12 of metadata references GLS2000. Online query led me to GLSDEM. I am assuming this is the DEM used in the L1T correction.
The original DEM is in WGS1984 geographic coordinate system. However, the image bands are in WGS1984 UTM projected coordinate system. Do I need to convert the DEM from geographic to projected coordinate system at all? I am asking because conversion will require bilinear interpolation and this will introduce distortion in the elevation values.
