i am a hobby-IT-person and currently stuck with some simple problem, maybe somebody can help me:
This is my working POSTGIS-function, source by underdark:
ALTER TABLE distance_graz ADD COLUMN nearest_node integer; CREATE TABLE temp AS SELECT a.osm_id, b.id, min(a.dist) FROM (SELECT planet_osm_point.osm_id, min(ST_Distance(planet_osm_point.way, distance_graz.the_geom)) AS dist FROM planet_osm_point, distance_graz GROUP BY planet_osm_point.osm_id) AS a, (SELECT planet_osm_point.osm_id, distance_graz.id, ST_Distance(planet_osm_point.way, distance_graz.the_geom) AS dist FROM planet_osm_point, distance_graz) AS b WHERE a.dist = b. dist AND a.osm_id = b.id GROUP BY a.osm_id, b.id; UPDATE distance_graz SET nearest_node = (SELECT id FROM temp WHERE temp.gid = distance_graz.gid); What it does is to get the node "a" with the minimal distance to another node "b" and write it in a new table
But now I want to refine this by only getting "nearest points "b"" if they are within a certain distance (5000m) to this point "a".
I think the best way to do this is by adding "ST_dwithin" to the quer:
SELECT planet_osm_point.osm_id, ST_DWithin(planet_osm_point.way,distance_graz.the_geom,5000) AS wit The Question now is how and where do i implement this?
Thanks in Advance for helping
