At 10.4.x scipy is included in your basic python install, which is great!
Working with Pandas DataFrame can make life easy, especially if you need to do it quickly.
import arcpy
import pandas as pd
import sys
def trace():
trace finds the line, the filename
and error message and returns it
to the user
import traceback
tb = sys.exc_info()[2]
tbinfo = traceback.format_tb(tb)[0]
# script name + line number
line = tbinfo.split(", ")[1]
# Get Python syntax error
synerror = traceback.format_exc().splitlines()[-1]
return line, __file__, synerror
with arcpy.da.SearchCursor(r"d:\temp\scratch.gdb\INCIDENTS_points",
["OBJECTID", "SHAPE@X", "SHAPE@Y"]) as rows:
try:
df = pd.DataFrame.from_records(data=rows,
index=None,
exclude=None,
columns=rows.fields,
coerce_float=True)
print ((df.columns[1], df.columns[2]))
print ((df[df.columns[1]].mean(), df[df.columns[2]].mean()))
except:
print trace()
Like normal, you create an arcpy.da cursor, then pass that generator into the DataFrame's from_records(). Once the data is loaded, like in my example, you can perform operations on the frame itself. For example let's say you needed the mean location of points. This can be quickly done by loading in all the location XY columns (SHAPE@X and SHAPE@Y) and performing a mean call on each column.
With this method you can't control the chunksize when loading the data, so be careful of your memory.
Copyright AJC
import arcpy
import pandas as pd
import sys
def trace():
to the user
import traceback
try:
index=None,
exclude=None,
coerce_float=True)
except:
print trace()
Copyright AJC
