reading GRASS vector map in python
I know similar questions have been asked several times, but none of the solutions seems suitable for my problem or don't work..
I computed flowlines using the r.flow tool from GRASS GIS, then I export these using v.out.ogr which gives me the files flowlines.dbf, flowlines.prj, flowlines.shp and flowlines.shx. The image shows the figure in GRASS of my flowlines over a DEM. gr
Now I need to read this shapefile into python and reproduce that same image in python. To read the file I downloaded the shapefile module, which seems to work fine, but after that I'm lost. I was told to use fiona module by a friend but it doesnt want to install on my ubuntu machine, not sure what's the problem, so a solution without fiona would be great..
Does anyone have good advice?
thanks a lot in advance!
