Raster Not Loading into Map Display - GRASS
I am very new to GRASS and I have been trying to load a raster using just the GUI. I have set my project to the projection of my .tiff file and extents. Using file > import raster I select the .tiff file and my raster imports with no warnings. The problem is I can't get the raster to appear in the map display window. I have tried to setting the computational region, which fails; saving and reloading, and starting a new project. Nothing seems to work. The raster shows up in QGIS without issue and works in ArcMAP, but not in GRASS. Does anyone have a solution or am I doing something wrong? Also, in the Layer Manager if I right click the raster layer I can't access the properties and all other actions fail when run.
