Here's a sample of my dataset (one cell) with 28 different raster values, representing 28 individual Float32 rasters with identical parameters.
0.0000264434, 0.0049953502, 0.0007529828, 0.0002075955, 0.0000516699972, 0.0000000000, 0.0053563155, 0.0000000000, 0.0000000000, 0.0073998945, 0.0000804775, 0.0000000000, 0.0000387653, 0.0000000000, 0.0000000000, 0.0000000000, 0.0000000000, 0.0000000000, 0.0007369027, 0.0000519922, 0.0053393530, 0.0000000000000, 0.0000000000000, 0.0000000000000, 0.0000808992875, 0.0000000000000, 0.0000000000000, 0.0000000000000, Due to system overload when I run the algorithm in a modeler, I've split the process into 4 groups of 7 layers by order of appearence. Each subgroup does the summary correct in all the calculation algorithms, including both SAGA ones: Raster Calculator and Grids Sum. However, when I do the final summarization of the 4 rasters, It appears that the SAGA algorithms return a different result
I tried to look if the SAGA algorithms truncate the data somehow but it doesn't seem to be the problem.
Any ideas why this is happening?
- Excel: 0.0251186417
- GDAL_CALC: 0.0251186417
- SAGA Raster Calculator: 0.060915395617485046
- SAGA Grids Sum:0.0012134892167523503
