Rappatools v3.41 for 3ds Max 2014-2017 (x64)
*RappaTools3* is an advanced toolbox that comes with a great variety of tools for the artist working in 3ds Max. The main focus is to speed up the workflow and to reduce the click count. It offers a wide variety of tools, everything from selection tools to rendering tools. It can help you through the entire process of creating a 3D art piece. :smile:صورة: https://u.damasgate.com/001/2/14atxz9zomt0lhedfptv.gif What's new:- Added repeat last.- Added support for Verts, Edges, Faces, Elements to RandomFly (each sub mode works in a different way).- Added Arc Tool to GeoOutline which is now a tool.- Added support for Splines to One Object, Explode Object, Detach Selection and Break Selection (also way faster than before).- Added extra functions to Move 2 Point such as planar rotate snap, move from point 2 point.- Added viewBlueprint so you can quickly add an image plane for the current view, they also move back so they don't intersect with each other.- Added support to CleanVerts and WeldVerts for subObjSelection.- Added support for EditPoly modifier to RandomSelect, RemveLoop, RemoveRing.- Added to WorkingPivot +shift to place the working pivot, when already active it keeps the direction.- Improved MakeMultiMaterial, collapse isn't required anymore, also from folder uses vray materials if it's assigned.- Improved Multi Hide, partial selection = hide, empty selection = unhide, all visible selected = invert.- GeoEdge is now a tool allowing to change the edge length on the fly.- Improved Create Polygon, also now it works with one edge selected (blender fill style) and inner verts are connected, inner edges are divided.- Improved Smart Toggles, and Sub Object Level toggles is more aware of the modifiers.- Improved CopyReplace, SetObjectHeight and VrayCameraFromView.- Improved Copy / Paste Material, it uses the scene material if the same.- RappaTools3 Quad Menu now can be assigned to either ctrl+shfit or ctrl+shift+alt.- Added Delete Empty Layers, toggles for display color, vertex color and shade vertex color.- Added RappaTools3 Menu and 2 extra HotBoxes.- Added Clean Arch Models to Unify Normals UI.- Various improvements and optimisations.For More Info - http://remusjuncu.com/rappatools/Download Link: https://drive.google.com/file/d/0B251ymLKgmB8V0Zkb3E4QVlLdDA/view
