I am using the ESRI spatial framework for Hadoop, that extends Hive to use spatial types and operations.
My objective is to translate a set of simple queries on PostGIS into Hadoop, in order to reach horizontal scalability.
I have a grid with a count for each cell.
The objective of my query is to select all cells that have a count higher than a certain threshold, and group(merge) all cells that are together. For instance in this case, I would end up with something like this: 4 polygons.
To do this in PostGIS, I use a combination of ST_Dump and ST_SnapToGrid
CREATE TABLE exploded ASSELECT(ST_Dump(st_union)).geomFROM (SELECT ST_Union(ST_SnapToGrid(geom,0.0001)) FROM grid where ptcnt > 'threshold) as q;Unfortunately, none of these functions is available on ESRI's spatial framework.
I can perform the threshold filter, but I have no way of aggregating the nearby geometries based on the proximity (a trick perform by the grid):
create table exploded as select u as geom from (select geom as u from grid_cnt where ptcnt > 11467) as q;
Does anybody can think of a workaround (perhaps using Union)?
